StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable
Quicklinx: 400YWS00 Mfr#: C6PATCH15BL
Length: 4.57m
Colour: Blue
23 in stock
£4.55 ex VAT
£5.46 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH15BL Cat 6 Patch Cable (15 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • 100% copper - a better value
  • 24 AWG wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
StarTech.com 15ft CAT6 Ethernet Cable - Blue Molded Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz - Category 6 Network Patch Cord UL/TIA (C6PATCH15BL) - patch cable - 4.57 m - blue
Patch cable - CAT 6
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
4.57 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: 110VDSLEXT, 110VDSLEXTEU, 110VDSLEXTGB, ET1000S40LC2, ET90110SC2, ET90110SM302, ET90110ST2, ET90110WDM2, ET91000LC, ET91000LC2, ET91000SC2, ET91000SM402, ST1000SPEX2, ST1000SPEX2L, ST1000SPEXD4, ST1000SPEXI, USB31GEHD, USB31GEVG, USBA2DPGB
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
4.57 m
Blue
Connector
RJ-45 - male
RJ-45 - male
CSA, ETL - up to 650 MHz
Length: 4.57m
Colour: Blue
Price Range Ex VAT: 0 - 50
