Wall-mount your server or networking equipment with a hinged rack design for easy access and maintenance. The RK1219WALLOH 12U 22in Depth Hinged Open Frame Wall Mount Server Rack lets you wall mount your (19-inch wide) servers, A/V or network equipment and features a hinged rack design that allows the entire frame to swing open for easy installation and maintenance of your equipment.
The 12U wallmount rack offers a 4 post design for additional support of your equipment, storing a maximum weight capacity of 63 kg (140 lbs). Constructed of high-quality SPCC cold-rolled steel for strength and durability, the open frame wallmount server rack allows for maximum airflow, and ships complete with all of the rack screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
- StarTech.com 12U Hinged Open Frame Wall Mount Server Rack - 4 Post 22 in. Depth Network Equipment Rack Cabinet - 140 lbs capacity (RK1219WALLOH) - rack - 12U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Package Content
- 48 mounting screws (10-32), 48 cage nuts
- Black
- Rack Size
- 22"
- Height (Rack Units)
- 12U
- Product Material
- Cold-rolled steel
- 60.4 cm x 55.5 cm x 64.7 cm
- 17.5 kg
- Hinged
- Limited lifetime warranty
- Product Type
- Rack
- Wall mountable
- Product Material
- Cold-rolled steel
- Package Content
- Rack Size
- 22"
- 12U
- 60.4 cm
- 55.5 cm
- 64.7 cm
- 17.5 kg
- Black
- Weight Limit
- 63.4 kg
- Hinged
- EIA-310-D, UL, RoHS
- Limited warranty: - lifetime
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.39 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £16.28 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £32.84 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.84 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £35.51 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.26 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £7.01 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £20.58 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £25.63 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £59.69 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £32.13 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.74 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £28.56 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.25 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £62.33 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £32.84 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £18.34 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £34.53 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £19.35 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.55 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £30.84 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £28.59 |
StarTech.com 19in Cable Management Panel | In Stock | £24.78 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £17.36 |
