Connect two 3-pin (TX3) fans to a single power supply connector. This TX3 Fan Power Splitter Cable lets you connect two 3-pin (TX3) fans to a single power supply connector, allowing you to optimize your cooling capability without having to upgrade the power supply. Providing a flexible way to position computer case fans as needed, the TX3 Fan Power Splitter cable offers a connection length of 1ft, eliminating the need to strain the connection from the computer power supply in order to reach the fan power connection. This high quality splitter cable is constructed of high quality materials to ensure long lasting performance.
- StarTech.com TX3 Fan Power Splitter Cable - Fan power splitter - 3 pin internal power (F) to 3 pin internal power (M) - 1 ft - TX3SPLIT12 - fan power splitter - 3 PIN internal power to 3 PIN internal power - 30 cm
- Length
- 30 cm
- Connector
- 3 PIN internal power - female
- Connector (Second End)
- 2 x 3 PIN internal power - male
- Limited lifetime warranty
- Length
- 30 cm
- Connector
- FCC, RoHS
