Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATARA12 Right Angle (90-degree) SATA cable (12in) enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 12in Right Angle SATA Cable - Serial ATA F/F - SATA cable - 30.48 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Right-angled connector
- Length
- 30.48 cm
- Connector
- 7 pin Serial ATA - receptacle
- Connector (Second End)
- Red
- Limited lifetime warranty
- Storage Cable Type
- SATA cable
- Interface Speed
- Length
- 30.48 cm
- Red
- Connector
