This 12in micro SATA extension cable features one male and one female micro SATA connector, allowing you to extend a micro SATA device connection by up to 1ft. A cost-effective solution, the extension cable not only simplifies drive installation by overcoming typical connection limitations, but also reduces the risk of damage to the drive or motherboard micro SATA connectors that could result from straining or "stretching" the cable to make the necessary data connection. The micro SATA extension cable is constructed of high quality materials to ensure a permanent solution.
- StarTech.com SATA extension cable - 30.5 cm
- SATA extension cable
- Length
- 30.5 cm
- Connector
- 16 pin Micro Serial ATA - male
- Connector (Second End)
- 16 pin Micro Serial ATA - female
- Limited lifetime warranty
- Storage Cable Type
- Length
- 30.5 cm
- Connector
- RoHS
