StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable
Quicklinx: 3ZM1WS00 Mfr#: CPUFANADAPT
Type: Power
27 in stock
£2.76 ex VAT
£3.31 inc VAT
The StarTech.com 6" 3-pin to Large Internal Power CPU Fan Adapter Cable allows a fan with a TX3 motherboard connector to draw power from a standard LP4 power supply connector.
StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable - power splitter - 15.2 cm
Power splitter
Length
15.2 cm
Connectors
4 PIN internal power - male
Connectors (Second End)
4 PIN internal power - female , 3 PIN internal power - male
P/N: ATX2POWER430, ATX2POWER530, FAN7X10TX3, FANP1003LD, FAN370PRO, FANDURONTB, FANP2SECC, FANBOX2
Power splitter
Length
15.2 cm
Connectors
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
Type: Power
Price Range Ex VAT: 0 - 50
