The StarTech.com 12cm x 12cm x 2.5cm (4 3/4" x 4 3/4" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 48 CFM (cubic feet per minute) of air. Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
- StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector (FANBOX12) - system fan kit
- Product Type
- System fan kit
- Fan Diameter
- 120 mm
- Noise Level
- 34 dBA
- 12 cm x 2.5 cm x 12 cm
- 129 g
- 2-year warranty
- Product Type
- System fan kit
- 12 cm
- 2.5 cm
- 12 cm
- 129 g
- Shipping Dimensions (WxDxH) / Weight
- 184 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Noise Level
- 34 dBA
- Limited warranty: - 2 years - carry-in
