This 50 Pack of 12-24 Server Rack Screws are convenient to have on hand for installing server, network, AV and other computer and storage equipment securely into your server cabinet or network data rack. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The bulk pack is also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a screw. The bulk package ensures that you have enough screws available to bolt all of your rack mount hardware to your rack, when you need to.
These rack mount bolts feature solid steel construction, with a nickel-plated finish to prevent rust.
- StarTech.com 12-24 Server Rack Screws - 50 pack - Nickel-plated - rack screws
- Product Type
- Rack screws
- Packaged Quantity
- 50 pieces
- Package Content
- 50 screws (12-24)
- Silver
- Product Material
- Steel
- 1.65 cm
- Bulk packaging
- Pricing Type
- US government
- Limited lifetime warranty
- Designed For
- P/N: RK630WALVS, RK830WALVS
- Packaged Quantity
- 50 pieces
- Product Type
- Rack screws
- Product Material
- Steel
- Package Content
- 50 screws (12-24)
- 1.65 cm
- Diameter
- 1.4 cm
- Shipping Dimensions (WxDxH) / Weight
- 21.8 cm x 12.5 cm x 1.4 cm / 190 g
- Silver
- Finish
- Nickel plated
- Bulk packaging
- RoHS, REACH
- Pricing Type
- US government
- TAA Compliant
- Limited warranty: - lifetime
- Designed For
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £99.99 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £45.21 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £78.51 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £48.25 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £34.53 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £120.51 |
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £252.52 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £237.02 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £205.22 |
StarTech.com 2-Post Server Rack - 42U | In Stock | £157.38 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £555.17 |
