StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC
Quicklinx: 949ZWS00 Mfr#: SMFIBLCLC10
Length: 10m
Colour: Yellow
Select:
13 in stock
£27.51 ex VAT
£33.01 inc VAT
Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCLC10 10m LC to LC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 10m Fiber Optic Cable - Single-Mode Duplex 9/125 LSZH - LC/LC - patch cable - 10 m - yellow
Patch cable - OS1
Fibre optic
Molded
Length
10 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x LC single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Patch cable - OS1
Fibre optic
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Molded
Length
10 m
Yellow
Connector
RoHS
Length: 10m
Colour: Yellow
Price Range Ex VAT: 0 - 50
