StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P0BWS00 Mfr#: MXTMMHQ10M
Length: 10m
10 in stock
£23.32 ex VAT
£27.98 inc VAT
Connect your VGA monitor with the highest quality connection available. This 10m high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 10m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 10 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
10 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
10 m
Connector
RoHS
7P0B StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.13
7P0B StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £23.32
7P0B StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £36.89
7P0B StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £50.35
Length: 10m
Price Range Ex VAT: 0 - 50
