StarTech.com 10m 40G QSFP+ Active DAC Cable
Quicklinx: D9V3WS00 Mfr#: QSFPH40GAC10
Select:
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across rack network switch or server connections.
StarTech.com Cisco QSFP-H40G-ACU10M Compatible 10m 40G QSFP+ to QSFP+ DAC Twinax, 40G QSFP+ Copper DAC 40 Gbps Low Power Active QSFP+ Transceiver Module DAC, 40GE Cable, Firepower, ASR1000 - Lifetime Warranty (QSFPH40GAC10) - 40GBase direct attach cable - 10 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Active cable
Length
10 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Active cable
Length
10 m
520 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
D9V3 StarTech.com 7m 40G QSFP+ Active DAC Cable In Stock £284.20
