StarTech.com 10GbE Fiber Media Converter
Quicklinx: C7CDWS00 Mfr#: ET10GSFP
Hurry, only 3 left in stock!
£887.82 ex VAT
£1,065.38 inc VAT
Convert and extend a high-speed, copper (10GBASE-T) connection over fiber (10GBASE-R), using the 10Gbe SFP+ transceiver of your choice. This 10GbE fiber media converter lets you scale your network using the 10Gb SFP+ transceiver that best suits your network type and distance requirements. It's a cost-effective way to convert copper to fiber, or fiber to copper, and it integrates easily into a range of 10Gb network infrastructures.
The 10G fiber converter delivers fast and reliable network access at longer distances than copper-based networks, making it ideal for server rooms or workstations in remote areas or in other buildings.
This high-performance fiber media converter integrates nicely into a variety of 10 Gigabit networks. And, because the card supports up to 10Gbps throughput, you can quickly bridge your traditional 10Gb copper (RJ45) based network across long distances using fiber-optic cable.
Now you can transfer large files and access high-bandwidth multimedia content in less time, even in remote locations.
With an open SFP+ slot, the 10GbE media converter adapts to your network connection and distance requirements. Plus, because it's compatible with most, it offers more possibilities for connecting devices and users to your network. With support for a wide range of transceivers, the network converter is ideal for dynamic, high-performance data centers.
The 10 Gigabit fiber media converter offers built-in management functionality, so you can quickly, yet effectively manage and customize your network settings through the local serial console port.
If your existing network consists of RJ45 copper-based devices and cables, you might not be ready for future network expansion. Because the newest fiber-based network switches feature SFP+ ports more often than RJ45 ports, you might need a converter to bridge your copper and fiber networks together.
This versatile fiber media converter is the perfect way to add users and devices to your network, now or in the future, while simultaneously interfacing your copper and fiber network mediums.
StarTech.com 10 Gigabit Ethernet Copper-to-Fiber Media Converter - Open SFP+ - Managed - 10G Ethernet Media Converter (ET10GSFP) - fibre media converter - 10 GigE
Fibre media converter - RJ-45 / SFP+
External
Australia, North America, United Kingdom, Europe
Cabling Type
10GBase-LR, 10GBase-ER, 10GBase-SR, 10GBase-LW, 100Base-TX, 1000Base-T, 10GBase-EW, 10GBase-T, 10GBase-SW
Data Transfer Rate
20 Gbps
10 GigE
AC 120/230 V
9.7 cm x 15.2 cm x 4.5 cm
680 g
P/N: 455883B21ST, EXSFP10GELRS, EXSFP10GESRS, J9152AST, JD092BST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRSST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRSTTA, SFP10GSRXST, SVA12M2NEUA, SVA12M5NA
External
Built-in Devices
SFP Module
Wired
Cabling Type
10 GigE
Data Transfer Rate
20 Gbps
Status Indicators
Power, alarm, link/activity, loop
Auto-uplink (auto MDI/MDI-X), full duplex mode, Digital Diagnostics Monitoring Interface (DDMI), Jumbo Frames support
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3ae
1 x 10Gb Ethernet - RJ-45 female , 1 x 10Gb Ethernet - SFP+ female
MTBF
57,000 hours
FCC, RoHS, MSA, RCM
External power adapter
AC 120/230 V
36 Watt
9.7 cm
15.2 cm
4.5 cm
680 g
50 °C
5 - 85% (non-condensing)
P/N: 455883B21ST, EXSFP10GELRS, EXSFP10GESRS, J9150AST, J9151AST, J9152AST, JD092BST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRMST, SFP10GLRSST, SFP10GLRST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST, SVA12M2NEUA, SVA12M5NA
C7CD StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.80
C7CD StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £46.91
C7CD StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £134.56
C7CD StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot In Stock £100.65
C7CD StarTech.com Gigabit Ethernet Fiber Media Converter Card Module with Open SFP Slot In Stock £93.38
C7CD StarTech.com PCIe 10Gb Fiber Card SFP+ NIC In Stock £115.40
C7CD StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £254.66
C7CD StarTech.com Fiber Media Converter - Open In Stock £62.11
C7CD StarTech.com Fiber Media Converter - w/ SFP In Stock £92.61
C7CD StarTech.com 2-Port PCI Express 10GBase-T Ethernet Network Card In Stock £269.50
C7CD StarTech.com GbE Fiber Media Converter 10km In Stock £193.91
C7CD StarTech.com GbE Fiber Media Converter 20km In Stock £179.60
C7CD StarTech.com 10GbE Fiber Media Converter In Stock £887.82
C7CD StarTech.com DC Power Adapter - 12V, 2A In Stock £13.33
C7CD StarTech.com DC Power Adapter - 12V, 5A In Stock £33.16
Price Range Ex VAT: £750 - £1000
Stock Status: In stock
