StarTech.com 10G-SFPP-BXD SFP Module - Lifetime Warranty - 10 Gbps - LC
Quicklinx: FJ9MWS00 Mfr#: 10G-SFPP-BXD-ST
The 10G-SFPP-BXD-ST is a Brocade 10G-SFPP-BXD compatible downstream fiber SFP transceiver which pairs with StarTech.com's 10G-SFPP-BXU-ST. They are designed, programmed and tested to work with 10GBase-BX compatible Brocade switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Brocade 10G-SFPP-BXD Compatible SFP+ Module, 10GBASE-BX-D, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+, LC 10km, Mini GBIC Transceiver SFP Plus Module - Lifetime Warranty (10G-SFPP-BXD-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-BX
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10GbE
Max Transfer Distance
10 km
5.84 cm x 1.39 cm x 1.26 cm
24 g
Plug-in module
Wired
Cabling Type
10GBase-BX
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-BX - LC single-mode female
MTBF
646,156,559 hours
FCC, MSA
1.3 Watt
5.84 cm
1.39 cm
1.26 cm
24 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
