StarTech.com 10G Open SFP+ NIC - PCIe
Quicklinx: CFQ2WS00 Mfr#: PEX10000SFPI
Get advanced connectivity over multimode or single-mode fiber, by adding a 10GBase-LR/SR open SFP+ port to your server or workstation. This fiber network card delivers reliable, high-performance network connectivity, by adding an open SFP+ slot to your server or high-powered workstation. It provides an easy and cost-effective way to upgrade your server or workstation to a 10 Gigabit fiber network using the SFP+ module of your choice and gives you the flexibility to use either multimode or single-mode fiber.
Several factors drive the need for more bandwidth in your network infrastructure. An increase in the number of network users and data-intensive applications, such as multimedia streaming and large file transfers all contribute to the need for more bandwidth in your network infrastructure. This fiber NIC lets you take advantage of the increased speed and stability of a 10 Gigabit network, with data transfers of up to 10Gbps.
The fiber NIC is compatible with most 10GbE SFP+ transceivers. This gives you flexible and scalable configuration options for connecting your computer directly to a fiber network, at greater distances.
The card features an open SFP+ slot with support for one interchangeable 10GBase SFP+ module. This gives you the option to use the fiber transceiver module that best suits your network needs based on distance and connector type. StarTech.com offers a variety of SFP+ transceiver modules including the SFP10GLRST single-mode SFP +, the SFP10GLRMST multi-mode SFP+, and SFP10GSRST multimode LC with DDM.
In addition, StarTech.com provides a dependable solution for linking telecom and data communications equipment, such as routers and switches.
The 10 Gigabit network card features the Intel 82599 chipset, delivering the power, performance and enhanced capabilities you need for reliable network connections to your server or computer. The Intel chip offers many advanced features including Intel Virtualization Technology for Connectivity, PXE network boot support and up to 15K jumbo frame support.
StarTech.com 10G Network Card - MM/SM - 1x Single 10G SPF+ slot - Intel 82599 Chip - Gigabit Ethernet Card - Intel NIC Card (PEX10000SFPI) - network adapter - PCIe 2.0 x8
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
1.8 cm x 13.5 cm x 12 cm
102 g
Cabling Type
Ethernet 10GBase-LR, Ethernet 10GBase-SR, Ethernet 10GBase-LRM
10GbE
Data Transfer Rate
10 Gbps
Jumbo frame size: 15000
IEEE 802.3ae, IEEE 802.3aq
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x LTS versions, Microsoft Windows Server 2019 (64-bit)
P/N: 455883B21ST, EXSFP10GELRS, EXSFP10GESRS, J9150AST, J9151AST, J9152AST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRSST, SFP10GLRST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRSTTA, SFP10GSRXST
Network adapter
Plug-in card
PCI Express 2.0 x8
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity
Flow control, full duplex capability, Jumbo Frames support
1 - SFP+
Low-profile bracket
FCC, RoHS
1.8 cm
13.5 cm
12 cm
102 g
50 °C
20 - 80%
P/N: 455883B21ST, EXSFP10GELRS, EXSFP10GESRS, J9150AST, J9151AST, J9152AST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRMST, SFP10GLRSST, SFP10GLRST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST
CFQ2 StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £36.36
CFQ2 StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.56
CFQ2 StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £46.24
CFQ2 StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £60.13
CFQ2 StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £35.41
CFQ2 StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £295.64
