The USBEXTAA10BK 10-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 10 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
- StarTech.com 10 ft Black USB 2.0 Extension Cable A to A - 10ft USB 2.0 Extension Cable - 10ft USB male female Cable (USBEXTAA10BK) - USB extension cable - USB to USB - 3 m
- Technology
- Double shielded
- Length
- 3 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, UUSBOTG
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 6ft High Speed USB 2.0 Cable | In Stock | £3.42 |
StarTech.com 6 ft Mini USB Cable - A to Mini B | In Stock | £3.36 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.68 |
StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M | In Stock | £3.35 |
StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M | In Stock | £4.59 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £4.23 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £1.27 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £3.35 |
StarTech.com 3m USB 2.0 A to B Cable - M/M | In Stock | £3.98 |
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.92 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.04 |
