StarTech.com 10ft C19 to C20 Power Cord
Quicklinx: B67YWS00 Mfr#: PXTC19201410
Select:
  • 3m
Connect a high-powered server to a power distribution unit. This C19 to C20 power cord from StarTech.com features 14 AWG wire that's suitable for high-power connections, making it perfect for server applications and connecting to a Power Distribution Unit (PDU).
Plus, you can use the cable to extend the reach of your existing power cord by 10 feet, which gives you the extra distance you need to place your devices according to your server room configuration.
StarTech.com 10ft (3m) Heavy Duty Extension Cord, IEC C19 to IEC C20 Black Extension Cord, 15A 250V, 14AWG, Heavy Gauge Power Extension Cable, IEC C19 to IEC C20 AC Power Cord - UL Listed - power cable - IEC 60320 C20 to IEC 60320 C19 - 3 m
Power cable
Service Junior Thermoplastic (SJT) jacket
Length
3 m
Connector
Power IEC 60320 C20
Connector (Second End)
Power IEC 60320 C19
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
14
Rated Voltage
AC 250 V
Length
3 m
Connector
Power IEC 60320 C20
Power IEC 60320 C19
RoHS
