StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone
Quicklinx: 6LCJWS00 Mfr#: DVID4N1USB10
Hurry, only 1 left in stock!
£19.26 ex VAT
£23.11 inc VAT
This 10ft four-in-one DVI/USB KVM cable integrates dual link DVI video quality with USB mouse and keyboard, 3.5mm audio out and microphone connections into a single, compact cable. The 4-in-1 KVM cable is a cost-effective and convenient solution that's suitable for use with dual link DVI supported USB KVM switches, allowing you to share a USB peripheral set between two computers configured for high definition output. The DVI/USB KVM cable provides guaranteed performance for dependable operation.
StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable w/ Audio & Microphone - keyboard / mouse / video / audio cable - 3 m
Keyboard / mouse / video / audio cable
Length
3 m
Connectors
24+1 pin digital DVI - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
Connectors (Second End)
24+1 pin digital DVI - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
P/N: SV431DVIDGB, SV431DVIDDU, SV431DDUSB, SV231DDUSB
Length
3 m
Connectors
RoHS
P/N: SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DVIDDU, SV231DVIUAHR, SV231QDVIUA, SV431DDUSB, SV431DVIDDU
6LCJ StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £14.08
6LCJ StarTech.com 10 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £18.53
6LCJ StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £19.26
6LCJ StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £28.71
6LCJ StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub In Stock £389.11
6LCJ StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £258.64
Price Range Ex VAT: 0 - 50
