Connect a PC directly to a multimode SC fiber network through an available PCI slot. The PCI100MMSC 100 Mbps fiber optic (MM SC) PCI Ethernet adapter card offers the perfect "Fiber-to-the-desk" solution allowing you to add a multimode SC fiber port to your system through an available standard or low-profile PCI slot.
A simple solution for connecting a computer directly to a fiber network, the fiber Ethernet adapter card can be installed in the computer through any PCI slot and is perfectly suited for high bandwidth applications with support for full duplex operation and 10/100 Mbps transfer speeds at distances of up to 2km.
Ideal for secure network setups, the PCI100MMSC offers a direct fiber connection which is not susceptible to electronic interference like standard RJ45 networks.
- StarTech.com 100Mbps Full/Low Profile Ethernet Multi Mode SC Fiber PCI NIC Card 2km - network adapter - PCI-X - 10/100 Ethernet x 2
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI-X
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- Ports
- 5.6 cm x 1.21 cm x 1.8 cm
- 80 g
- Cabling Type
- Ethernet 100Base-FX
- Data Transfer Rate
- 100 Mbps
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Windows 10 (32/64 bits)
- 2-year warranty
- Network adapter
- Form Factor
- PCI-X
- Bus Voltage
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 100 Mbps
- Status Indicators
- Link/activity
- Full duplex capability
- 2 x 100Base-FX - SC
- Compatible Slots
- 1 x PCI-X
- OS Required
- 5.6 cm
- 1.21 cm
- 1.8 cm
- 80 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 5 - 95%
