The MASFP1GBLX10 is a Cisco Meraki MA-SFP-1GB-LX10 compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco Meraki brand switches and routers. It delivers dependable 1GbE (100Mbps) connectivity over fiber cable, for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Cisco Meraki MA-SFP-1GB-LX10 Compatible SFP Module, 1000BASE-LX, 1GbE SMF Optic Transceiver, 1GE Gigabit Ethernet LC Connector, 10km, 1310nm Cisco Meraki MS225, MX400, MS250 - Lifetime Warranty (MASFP1GBLX10) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Juniper SFP-1GE-LX
- 1.37 cm x 5.66 cm x 1.25 cm
- 28 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LX
- 1GbE
- 1.25 Gbps
- 1310 nm
- 10 km
- Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3z
- 1 x Ethernet 1000Base-LX - LC single-mode female
- UL, FCC, RoHS, MSA
- 1.37 cm
- 5.66 cm
- 1.25 cm
- 28 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 95%
