StarTech.com 1000 Mbps Gigabit Single Mode Fiber Media Converter LC 40 km
Quicklinx: 85DCWS00 Mfr#: ET1000S40LC2
Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40km over Single Mode LC fiber. The ET1000S40LC2 1000 Mbps Gigabit Single-Mode Fiber Media Converter (LC, 40 km) enables you to extend a Gigabit Ethernet network over single-mode fiber, at distances up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
StarTech.com 1000 Mbps Gigabit Single-Mode Copper to Fiber Media Converter - Ethernet (1000Base-T) to LC Fiber Converter (ET1000S40LC2) - fibre media converter - 1GbE
Fibre media converter - RJ-45 / LC single-mode
External
North America, United Kingdom, Europe
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
40 km
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.62 kg
P/N: SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
40 km
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC single-mode female x 2
MTBF
65,000 hours
Plug and Play, FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.62 kg
60 °C
10 - 90% (non-condensing)
85DC StarTech.com Fiber Media Converter - w/ SFP In Stock £82.65
85DC StarTech.com GbE Fiber Media Converter 10km In Stock £207.57
85DC StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
85DC StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
