The MCMGBSC15GB Ethernet Media Converter converts transparently to/from 1000Base-T Ethernet signals and 1000Base-LH optical signals, providing a cost-effective Ethernet-fiber/copper-fiber link, in order to extend an Ethernet network connection over a Single Mode fiber backbone. Supporting a maximum Single Mode fiber optic cable distance of 15km (9.32 miles), the Fiber Media Converter delivers a simple solution for connecting Gigabit Ethernet networks to remote locations using SC-terminated SM fiber, while ensuring solid network performance and scalability.
- StarTech.com 1000 Mbps Gigabit SM Fiber Ethernet Media Converter SC - fibre media converter
- Fibre media converter - RJ-45 / SC single-mode
- Form Factor
- External
- Localisation
- United Kingdom
- Cabling Type
- 1000Base-LX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Max Transfer Distance
- 15 km
- 7.3 cm x 9.9 cm x 2.7 cm
- 450 g
- 1-year warranty
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 1310 nm
- 15 km
- Status Indicators
- Port duplex mode, power, link OK
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000Base-LX - SC single-mode x 2
- FCC, RoHS
- Power Device
- External power adapter
- 7.3 cm
- 9.9 cm
- 2.7 cm
- 450 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
