StarTech.com 1000 Mbps Gigabit Multi Mode Fiber Ethernet Media Converter SC 550m
Quicklinx: 6LD5WS00 Mfr#: MCMGBSC055GB
Convert an RJ-45 Gigabit Ethernet network connection to multimode fiber. The MCMGBSC055GB Ethernet media converter converts transparently to/from 1000Base-T Ethernet signals and 1000Base-SX optical signals, providing a cost-effective Ethernet-fiber/copper-fiber link, in order to extend an Ethernet network connection over a multimode fiber backbone.
Supporting a maximum multimode fiber optic cable distance of 550m (0.34 miles), the fiber media converter delivers a simple solution for connecting Gigabit Ethernet networks to remote locations using SC-terminated MM fiber, while ensuring solid network performance and scalability.
StarTech.com 1000 Mbps Gigabit MM Fiber Ethernet Media Converter SC - fibre media converter
Fibre media converter - RJ-45 / SC multi-mode
External
United Kingdom
Cabling Type
1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
550 m
7.3 cm x 9.9 cm x 2.7 cm
450 g
External
United Kingdom
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Status Indicators
Port duplex mode, power, link OK
Auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000Base-SX - SC multi-mode x 2
FCC, RoHS
External power adapter
7.3 cm
9.9 cm
2.7 cm
450 g
