Convert an RJ-45 Gigabit Ethernet network connection to multimode fiber. The MCMGBSC055GB Ethernet media converter converts transparently to/from 1000Base-T Ethernet signals and 1000Base-SX optical signals, providing a cost-effective Ethernet-fiber/copper-fiber link, in order to extend an Ethernet network connection over a multimode fiber backbone.
Supporting a maximum multimode fiber optic cable distance of 550m (0.34 miles), the fiber media converter delivers a simple solution for connecting Gigabit Ethernet networks to remote locations using SC-terminated MM fiber, while ensuring solid network performance and scalability.
- StarTech.com 1000 Mbps Gigabit MM Fiber Ethernet Media Converter SC - fibre media converter
- Fibre media converter - RJ-45 / SC multi-mode
- Form Factor
- External
- Localisation
- United Kingdom
- Cabling Type
- 1000Base-SX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Max Transfer Distance
- 550 m
- 7.3 cm x 9.9 cm x 2.7 cm
- 450 g
- 2-year warranty
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 850 nm
- 550 m
- Status Indicators
- Port duplex mode, power, link OK
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000Base-SX - SC multi-mode x 2
- FCC, RoHS
- Power Device
- External power adapter
- 7.3 cm
- 9.9 cm
- 2.7 cm
- 450 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
