StarTech.com 1000 Mbps Gigabit Ethernet Multi Mode SC Fiber PCI Express Card - 550m
Quicklinx: 6BDGWS00 Mfr#: PEX1000MMSC
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC
Type: Network adapter
Hurry, only 3 left in stock!
£113.75 ex VAT
£136.50 inc VAT
Add a gigabit Multi-mode SC fiber port to your system through PCI Express. The PEX1000MMSC 1000 Mbps Gigabit Ethernet Multi Mode SC Fiber PCI Express Card - 550m offers the perfect "Fiber-to-the-desk" solution, turning an available PCIe slot into an SC Multimode fiber connection. A simple solution for connecting a computer directly to a high-speed fiber network, the Fiber Gigabit Ethernet Adapter card is perfectly suited to high bandwidth applications with support for Full Duplex operation and gigabit transfer speeds. Ideal for secure network setups, the PEX1000MMSC offers a direct fiber connection which is not susceptible to electronic interference like standard RJ45 networks.
StarTech.com 1000 Mbps Gigabit Ethernet MM SC Fiber PCI Express Card - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
1000Base-FX
2 cm x 10.9 cm x 8.3 cm
80 g
Cabling Type
Ethernet 1000Base-FX
GigE
Max Transfer Distance
550 m
IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Network adapter
Plug-in card
PCI Express x1
PCIe 1.0a
Ports
1000Base-FX
Wired
Cabling Type
Gigabit Ethernet
550 m
Remote Management Protocol
SNMP 1
Status Indicators
Link OK, link/activity
Full duplex capability, wake on LAN (WOL), Jumbo Frames support
1 x 1000Base-FX - SC multi-mode - x 2
Compatible Slots
1 x PCI Express x1
ACPI 2.0, FCC, RoHS
2 cm
10.9 cm
8.3 cm
80 g
45 °C
5 - 95%
6BDG StarTech.com 1000 Mbps Gigabit Ethernet Multi Mode SC Fiber PCI Express Card - 550m In Stock £113.75
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 100 - 150
