StarTech.com 100 ft Coax High Resolution Monitor VGA Cable -  HD15 M/M
Quicklinx: 6BBGWS00 Mfr#: MXT101MMH100
Length: 30.5m
£51.14 ex VAT
£61.36 inc VAT
This 100ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends. A reliable solution for a wide range of applications, this high resolution VGA (SVGA) cable features two hd15 male connectors and provides a connection distance of 100ft.
StarTech.com 100 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 30.5 m
VGA cable
Coaxial
Length
30.5 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
FCC
VGA cable
Coaxial
Length
30.5 m
Connector
FCC
Length: 30.5m
Price Range Ex VAT: 50 - 100
