Add ten USB 3.0 ports, including two charging downstream ports, to your computer. This 10-port USB 3.0 hub enhances your system's capabilities by providing fast-charging for mobile devices, plus quick access to your USB devices, making it perfect for business or home-office settings.
As a charging station, the hub features two easy-access 1.5 amp charge-and-sync ports, so you can easily fast-charge your smartphones, tablets and other mobile devices. Plus, you can still connect all of your vital peripherals to the remaining data ports. Because the hub supports USB Battery Charging Specification 1.2, you can charge most mobile devices, including Apple and Samsung Galaxy devices.
Designed for maximum scalability, this 10-port hub boosts your productivity by putting all of your USB devices within easy reach. With USB 3.0 transfer rates up to 5Gbps, it supports high-bandwidth devices such as external hard drive enclosures, flash drives, high-resolution webcams, video cameras, and more.
With its sleek and compact design, you can easily position the USB 3.0 (also known as USB 3.1 Gen 1) hub on your desk or workspace to make your USB devices more accessible. There's also ample space between the USB 3.0 ports, so it's easy to plug and unplug the devices you use the most.
The USB 3.0 hub is natively supported in virtually all operating systems, which makes for an easy setup with no driver installation required.
Fast-charge your mobile devices
As a charging station, the hub features two easy-access 1.5 amp charge-and-sync ports, so you can easily fast-charge your smartphones, tablets and other mobile devices. Plus, you can still connect all of your vital peripherals to the remaining data ports. Because the hub supports USB Battery Charging Specification 1.2, you can charge most mobile devices, including Apple and Samsung Galaxy devices. -
Increase your productivity with ten USB 3.0 ports
Designed for maximum scalability, this 10-port hub boosts your productivity by putting all of your USB devices within easy reach. With USB 3.0 transfer rates up to 5Gbps, it supports high-bandwidth devices such as external hard drive enclosures, flash drives, high-resolution webcams, video cameras, and more. -
Designed for easy use
With its sleek and compact design, you can easily position the USB 3.0 hub on your desk or workspace to make your USB devices more accessible. There's also ample space between the USB 3.0 ports, so it's easy to plug and unplug the devices you use the most.
- StarTech.com 10-Port USB 3.0 Hub with Charge and Sync Ports - 2 x 1.5A Ports - USB peripheral sharing switch - 10 ports
- Subtype
- USB
- Ports
- 10 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V 1.5 A
- 6 cm x 24 cm x 2.4 cm
- 140 g
- Black
- Localisation
- Australia, North America, United Kingdom, Europe
- 2 years warranty
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Processor
- 1 x VIA VL812
- Status Indicators
- Port status
- 10 x USB 3.0 Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Electric Current Required
- 1.5 A
- 48 Watt
- Black
- Cables Included
- 1 x SuperSpeed USB cable
- FCC, RoHS, WEEE, RCM
- Localisation
- 6 cm
- 24 cm
- 2.4 cm
- 140 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
