Scale your network and connect up to 10 different Gigabit Ethernet devices, including 8x RJ45 + 2x fiber optic connections using the SFPs of your choice. The IES101002SFP 10-port Ethernet switch delivers flexibility and control of your network by letting you connect a combination of RJ45 and fiber Ethernet devices. Plus, with Layer 2 management capabilities you can customize your settings to achieve optimal network performance, offering improved efficiency and reliability over typical Layer 1 and unmanaged network switches.
This versatile switch adapts to your network fiber connection and distance needs to offer flexible configuration via 2 open SFP slots, and you can choose your preferred GbE SFP transceiver as required. Plus, you can integrate fiber devices and cables into your network infrastructure, which can help to eliminate bandwidth, latency, and electronic interference issues.
To avoid the nuisance and added costs of different and additional switch types, this clever switch also offers 8 RJ45 Ethernet ports, giving you two effective interfaces for connecting both fiber and copper connections to just a single network device.
The scalable switch offers Layer 2 management capabilities, which lets you control packet traffic on a busy network, and in turn provides enhanced efficiency and stability of networked applications. For even more flexibility and control, the IES101002SFP offers essential features such as support for jumbo frames, link aggregation, VLAN tagging, and web or console-based command lines, as well as rackmount installation brackets.
StarTech.com - switch - 10 ports - Managed - rack-mountable
Switch - 10 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Forwarding performance (full duplex): 2 Gbps
Jumbo Frame Support
9.6KB
Remote Management Protocol
SNMP
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Energy Efficient Ethernet, Management Information Base (MIB), Network Access Control (NAC), link aggregation trunking, tagged VLAN, 4MB packet buffer, 802.1x authentication
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3az
AC 90 - 260 V
26.3 cm x 16 cm x 4.4 cm
1.5 kg
North America, United Kingdom, Europe
P/N: 3CSFP91ST, 453154B21ST, EXSFP1GELXST, EXSFP1GESXST, EXSFP1GETST, GLCEXSMDST, GLCLHSMDSTTA, GLCLXSMRGDST, GLCSXMMDST, GLCSXMMDSTT, GLCSXMMRGDST, GLCTEST, GLCTSTTAA, GLCZXSMRGDST, JD089BST, JD118BST, JD119BST, MASFP1GBLX10, MASFP1GBSXST, MASFP1GBTXST, SFP1GELXST, ST12MHDLAN4K, ST12MHDLAN4R
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Jumbo Frame Support
9.6KB
SNMP
Status Indicators
Power, system, link/activity
8 x 100Base-TX RJ-45 , 1 x console RJ-45
Expansion Slots
2 (total) / 2 (free) x SFP (mini-GBIC)
External power adapter
AC 90 - 260 V
14 Watt
Mounting brackets
UL, FCC, RoHS
26.3 cm
16 cm
4.4 cm
1.5 kg
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
90 °C
Humidity Range Storage
P/N: 3CSFP91ST, 453154B21ST, EXSFP1GELXST, EXSFP1GESXST, EXSFP1GETST, GLCEXSMDST, GLCLHSM10PST, GLCLHSMD10ST, GLCLHSMDST, GLCLHSMDSTTA, GLCLXSMRGDST, GLCSXMM10PST, GLCSXMMDST, GLCSXMMDSTT, GLCSXMMRGDST, GLCT10PKST, GLCTEST, GLCTST, GLCTSTTAA, GLCZXSMRGDST, J4858C10PKST, J4858CST, J4859C10PKST, J4859CST, J8177C10PKST, J8177CST, JD089BST, JD118BST, JD119BST, MASFP1GBLX10, MASFP1GBSXST, MASFP1GBTXST, SFP1GELXST, SFPC1110, SFPG1320C, SFPGESST, SFPGLCLHSMST, SFPGLCSXMMST, SFPSXMM, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR
B9GC StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F In Stock £21.42
B9GC StarTech.com 100ft Black Cat6 Patch Cable In Stock £39.11
B9GC StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £43.94
B9GC StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £26.11
B9GC StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £26.34
B9GC StarTech.com 5 Port Industrial Gigabit Ethernet Switch In Stock £136.20
B9GC StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £242.93
B9GC StarTech.com Gb RJ45 Copper SFP - 10 Pack In Stock £266.91
B9GC StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £286.64
B9GC StarTech.com Gigabit RJ45 Copper SFP In Stock £40.14
B9GC StarTech.com Cisco GLC-TE Compatible SFP Copper Module - 1000BASE-T In Stock £48.71
