Attach a PC VGA port to a switchbox. This 10-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 10ft Coax VGA Cable (MXT101MMHQ10).
- StarTech.com 10 ft VGA Monitor Cable - HD15 MM - VGA cable - 3 m
- VGA cable
- Technology
- Shielded
- Length
- 3 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- FCC
- Grey
- Limited lifetime warranty
- Designed For
- P/N: DP2VGA3, USB32VGAES, USB32VGAPRO
- VGA cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 3 m
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- FCC
- Designed For
