Attach a PC VGA port to a switchbox. This 10-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 10ft Coax VGA Cable (MXT101MMHQ10).
StarTech.com 10 ft. (3 m) VGA to VGA Cable - HD15 VGA Cable - 800x600 Resolution - Male/Male - VGA Monitor Cable (MXT101MM10) - VGA cable - 3 m
VGA cable
Shielded
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
FCC
Grey
P/N: CDP2VGA, CDP2VGAFC, SV231DVGAU2A, SV431DVGAU2A
VGA cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
3 m
Grey
Connector
FCC
