Product
StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M
Quicklinx: 401WWS00 Mfr#: USB2HAB10
Length: 3m
Hurry, only 3 left in stock!
£3.81 ex VAT
£4.57 inc VAT
Express delivery Delivered on Tuesday
Connect USB 2.0 peripherals to your computer. The USB2HAB10 10ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M - USB cable - 3 m
USB cable
Molded
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: PEXUSB400, SV231DPUA, SV231DPDDUA, PEXUSB7LP, ST7200USBM, USBVGADOCK2, SV431DPUA, SV231HDMIUA, SAT3510U2FGB, SAT3510U2F, SV431DDVDUA, SV231DDVDUA, SV431DD2DUA, SV231DD2DUA, SV231DPU, CBUSB22, SV431DVIDGB, USBVGADOCKGB, ST7202USBGB, SAT3520U2RGB, ST4202USBGB, SAT3510U2VGB, SAT3510U2V
USB cable
Molded
Length
3 m
Connector
USB / USB 2.0, FCC
StarTech.com 1 Port USB 2.0 & 2 Port FireWire ExpressCard Laptop Combo Adapter Card, 2 Port CardBus Laptop USB 2.0 PC Card Adapter, 2 Port ExpressCard Laptop USB 2.0 Adapter Card, 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub, 2 Port USB to RS232 Adapter / 2 Port USB Hub, 3 Port PCI High Speed USB 2.0 Adapter Card, 3 Port PCI Low Profile High Speed USB 2.0 Adapter Card, 3 Port USB 2.0 Hub & 16-in-1 Multi Media Memory Card Reader, 3.5in Black Multi Port Panel for Front Drive Bay, 3.5in Silver FireWire 400 USB to IDE External Hard Drive Enclosure, 3.5in Silver USB 2.0 One Button IDE External Hard Drive Enclosure, 3.5in Silver USB 2.0 to Dual SATA JBOD External Hard Drive Enclosure, 3.5in USB FireWire SATA External Hard Drive Enclosure, 3.5in USB to SATA External Hard Drive Enclosure w/ One Button Backup, 4 Independent Port PCI Express USB 2.0 Adapter Card, 4 Port CardBus Laptop USB 2.0 PC Card Adapter, 4 Port Dual DVI USB KVM Switch w/ Audio & USB Hub, 4 Port ExpressCard Laptop USB 2.0 Adapter Card, 4 Port PCI High Speed, 4 Port Silver USB 2.0 Hub, 4 Port USB 2.0 3 Port IEEE 1394a PCI USB Firewire Combo Adapter Card, 4 Port USB 2.0 Hub - Hub - 4 ports - Hi-Speed USB, 4-in-1 USB VGA Adapter and Docking Station, 5 Port PCI Express USB 2.0 Adapter Card, 5.25in Silver USB to IDE External Optical Drive Enclosure, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, 7 Port Compact Black USB 2.0 Hub, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, 8 Port USB to RS232 Serial DB9 Adapter Hub, Dual Profile PCI Express to 34mm and 54mm ExpressCard Adapter Card, USB 2.0 to SATA adapter, USB Powered Laptop Cooler with 2 Built in Fans , StarTech.com InfoSafe 3.5" USB 2.0 SATA Aluminum HD Enclosure, 3.5" USB 2.0 SATA Hard Drive Enclosure, 3.5" USB 2.0 to IDE/SATA Hard Drive Enclosure, 5.25" eSATA/USB 2.0 SATA Optical Drive Enclosure, USB 2.0 Dual 3.5" SATA Drive Enclosure w/RAID
Length: 3m
Price Range Ex VAT: 0 - 50
