StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M
Quicklinx: 401WWS00 Mfr#: USB2HAB10
Length: 3m
More than 50 in stock
£3.83 ex VAT
£4.59 inc VAT
Connect USB 2.0 peripherals to your computer. The USB2HAB10 10ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M - 10ft type a to b USB Cable - 10ft a to b USB 2.0 Cable (USB2HAB10) - USB cable - USB to USB Type B - 3 m
USB cable
Molded
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: ICUSB23208FD, ICUSB23216FD, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PM1115UW, PM1115UWEU, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI2, SV231DPDDUA2, SV231USBDDM, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, SV431DVIUAQV, SV431DVIUDDM, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB3EXT6INBK
USB cable
Molded
Length
3 m
Connector
USB / USB 2.0, FCC
P/N: ICUSB23208FD, ICUSB23216FD, ICUSB2324, ICUSB2324I, ICUSB2328, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PCI420USB, PCI625USB2I, PCIUSB7, PEXUSB4DP, PM1115UW, PM1115UWEU, RACKCOND1701, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI, ST4200MINI2, ST4200USBM, ST4202USB, ST4202USBGB, ST7200USBM, ST7202USB, ST7202USBGB, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPUA, SV231DVIDDU, SV231DVIUA, SV231DVIUDDM, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV231USB, SV231USBDDM, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV431DVIDDU, SV431DVIUAQV, SV431DVIUDDM, SV431TDVIUA, SV431USB, SV431USBDDM, SV565USAGB, SV565UTPDUV, SV565UTPHDU, SV831DVIU, USB1000IP, USB2001EXT2, USB2001EXT2NA, USB2002EXT2, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB2AAEXT10M, USB2AAEXT15M, USB2AAEXT20M, USB2AAEXT35M, USB3EXT6INBK, USB421, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4, USBVGADOCK2
401W StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.83
401W StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.18
401W StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £16.63
401W StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £26.04
Length: 3m
Price Range Ex VAT: 0 - 50
