Do you plan your office layout around the length of your cables? StarTech.com's Standard Straight-Through Cables will help you organize your workspace so that you can get back to the task at hand.
- StarTech.com 10 ft Straight Through Serial Parallel Cable - DB25 M/M - serial / parallel cable - 3 m
- Serial / parallel cable
- Length
- 3 m
- Connector
- 25 pin D-Sub (DB-25) - male
- Connector (Second End)
- Limited lifetime warranty
- Length
- 3 m
- Connector
