StarTech.com 10 ft Straight Through Serial Cable - M/F
Quicklinx: 8CNTWS00 Mfr#: MXT10010
Length: 3m
£4.07 ex VAT
£4.88 inc VAT
This 9-pin Straight Through Serial Cable features a DB9 male connector and a DB9 female connector, allowing you to extend a serial device connection by up to 10ft. The serial cable is constructed using high quality components and design.
StarTech.com 10 ft Straight Through Serial Cable - M/F - Serial extension cable - DB-9 (M) to DB-9 (F) - 10 ft - gray - MXT10010 - serial extension cable - DB-9 to DB-9 - 3 m
Length
3 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
P/N: IC232TTL, ICUSB23208FD, ICUSB23216FD, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232DB25, ICUSB232PRO, ICUSB232V2, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S1P952, PEX4S232485, ST121UTP232
Length
3 m
Grey
Connector
FCC
8CNT StarTech.com 6ft VGA Monitor Extension Cable - HD15 M/F In Stock £3.83
Length: 3m
Price Range Ex VAT: 0 - 50
