Product
StarTech.com 10 ft Straight Through Serial Cable - M/F
Quicklinx: 8CNTWS00 Mfr#: MXT10010
Length: 3m
15 in stock
£4.04 ex VAT
£4.84 inc VAT
Standard delivery Delivered within 3-5 working days
This 9-pin Straight Through Serial Cable features a DB9 male connector and a DB9 female connector, allowing you to extend a serial device connection by up to 10ft. The serial cable is constructed using high quality components and design.
StarTech.com 10 ft Straight Through Serial Cable - M/F - serial extension cable - 3 m
Serial extension cable
Length
3 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
P/N: PCI2S232485I, PCI8S950LP, PCI1S650DV
Length
3 m
Grey
Connector
FCC
StarTech.com 2 Port RS232/422/485 PCI Serial Adapter Card w/ ESD Protection, 8 Port Low Profile RS232 PCI Serial Card with 16950 UART, PCI1S650DV
Length: 3m
Price Range Ex VAT: 0 - 50
