This 9-pin Straight Through Serial Cable features a DB9 male connector and a DB9 female connector, allowing you to extend a serial device connection by up to 10ft. The serial cable is constructed using high quality components and design.
- StarTech.com 10 ft Straight Through Serial Cable - M/F - Serial extension cable - DB-9 (M) to DB-9 (F) - 10 ft - gray - MXT10010 - serial extension cable - DB-9 to DB-9 - 3 m
- Length
- 3 m
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Grey
- Limited lifetime warranty
- Designed For
- P/N: 1P3FPC-USB-SERIAL, IC232TTL, ICUSB23208FD, ICUSB23216FD, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232DB25, ICUSB232PRO, ICUSB232V2, PCI2S1P2, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S1P952, PEX4S232485, ST121UTP232
- Length
- 3 m
- Grey
- Connector
- FCC
- Designed For
