Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH10RD Cat 6 Patch Cable (10 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
100% copper - a better value
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment. -
24 AWG wire
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire. -
50-micron gold connectors
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
- StarTech.com 10ft CAT6 Ethernet Cable - Red Snagless Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz Category 6 Network Patch Cord UL/TIA (N6PATCH10RD) - patch cable - 3 m - red
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded, snagless
- Length
- 3 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- UL, RoHS, ETL - up to 650 MHz
StarTech.com 10 ft White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.25 |
StarTech.com 10 ft Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.25 |
StarTech.com 10ft Orange Cat6 Patch Cable | In Stock | £4.25 |
StarTech.com 10 ft Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.25 |
StarTech.com 10 ft Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.25 |
StarTech.com 10ft Yellow Cat6 Patch Cable | In Stock | £4.25 |
StarTech.com 10 ft Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.26 |
