This 10ft PS/2 keyboard/mouse extension cable features a 6 DIN male connector and a 6 DIN female connector, allowing you to extend the connection distance between a PS/2 mouse or keyboard and the host computer by up to 10ft.
The extension cable offers a cost-effective and convenient way to connect PS/2 peripherals at longer distances than would typically be possible, allowing you to position peripherals as needed, without the hassle of connection length limitations.
- StarTech.com 10 ft PS/2 Keyboard / Mouse Extension Cable - M/F - keyboard / mouse cable - 3 m
- Keyboard / mouse cable
- Length
- 3 m
- Connector
- 6 pin mini-DIN (PS/2 style) - male
- Connector (Second End)
- 6 pin mini-DIN (PS/2 style) - female
- Limited lifetime warranty
- Designed For
- P/N: PS2PLATE, USBPS2PC
- Length
- 3 m
- Connector
- Designed For
