StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black
Quicklinx: 920HWS00 Mfr#: MDP2VGAMM10B
Length: 3.05m
£24.13 ex VAT
£28.95 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 10ft long black cable. The MDP2VGAMM10B 10ft active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped device (Desktop PC, Mac, Laptop, Ultrabook, etc.) directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your Mini DisplayPort computer to work with a VGA monitor or projector.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 10ft Mini DisplayPort to VGA Adapter Cable mDP to VGA - Black - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration), Thunderbolt port compatible
1 - 3 m
FCC, RoHS, WEEE
90 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85%
920H StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £19.63
920H StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £18.18
920H StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White In Stock £19.27
920H StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White In Stock £21.19
920H StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £24.64
920H StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £24.13
920H StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White In Stock £22.16
920H StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White In Stock £24.89
Length: 3.05m
Price Range Ex VAT: 0 - 50
