Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM10 10ft Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
- StarTech.com 10ft Mini DisplayPort to DisplayPort Cable - M/M - mDP to DP 1.2 Adapter Cable - Thunderbolt to DP w/ HBR2 Support (MDP2DPMM10) - DisplayPort cable - 3 m
- DisplayPort cable
- Length
- 3 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - male
- RoHS
- Limited lifetime warranty
- Designed For
- P/N: BOX4HDECP, CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, DPBOOST, HD2DP, MDPEXT3, SP123DP, SV431DPDDUA2, SV431DPUA2
- DisplayPort cable
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Nickel
- Length
- 3 m
- Connector
- 20 pin DisplayPort - male
- RoHS
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £8.65 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.19 |
StarTech.com 10 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £11.20 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £14.55 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £8.58 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.28 |
StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £14.97 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £21.08 |
StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter | In Stock | £91.20 |
