StarTech.com 10 ft IEEE-1394 FireWire Cable 6-6 M/M
Quicklinx: 402PWS00 Mfr#: 1394_10
Length: 3m
£5.48 ex VAT
£6.57 inc VAT
Turn up the heat with the 10 foot StarTech.com IEEE-1394 FireWire cable. Capable of transferring data at up to 400Mbps and daisy chaining up to 63 devices with cables up to 14 feet long, FireWire is a technology that StarTech.com is excited to offer. Providing the high-speed link required for FireWire peripherals to communicate with a PC or with each other as well as the ability to transfer digital video files from camcorders to PCs, each cable is manufactured using IEEE-1394 rated wire for full compatibility and reliability.
StarTech.com 10 ft IEEE-1394 FireWire Cable 6-6 M/M - IEEE 1394 cable - 3 m
IEEE 1394 cable
Length
3 m
Connector
6 PIN FireWire - male
Connector (Second End)
IEEE 1394
P/N: EC13942A2, PEX1394B3LP, SAT3510U2FGB, SAT3510U2F, SAT2510U2F, 35BAYPANELBK, EC1U2F, EC13942, PEX13943, IDECASE35U2F, CB1394B3, PCI1394_2LP, PCI3UV22F, CB1394_2, PCI1394_2, PCI1394MPGB, PCI1394_4GB, CB1394GB, PCI1394_4, PCI1394MP, CB1394
IEEE 1394 cable
Length
3 m
Connector
IEEE 1394
StarTech.com 1 Port USB 2.0 & 2 Port FireWire ExpressCard Laptop Combo Adapter Card, 2 Port ExpressCard 1394a FireWire Laptop Adapter Card, 2 Port ExpressCard Laptop 1394a Firewire Adapter Card, 2 Port IEEE-1394 FireWire PCI Card with Digital Video Editing Kit, 2.5in USB FireWire SATA External Hard Drive Enclosure, 3 Port CardBus 1394a FireWire Adapter Card - Digital Video Editing Kit, 3 Port CardBus PCMCIA 1394b FireWire Laptop Adapter Card, 3 Port PCI Low Profile 1394a FireWire Adapter Card, 3.5in Black Multi Port Panel for Front Drive Bay, 3.5in Silver FireWire 400 USB to IDE External Hard Drive Enclosure, 3.5in USB FireWire SATA External Hard Drive Enclosure, 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal, 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit, 4 Port PCI Express 1394a FireWire Adapter Card - 3 External 1 Internal, 4 Port USB 2.0 3 Port IEEE 1394a PCI USB Firewire Combo Adapter Card
Length: 3m
Price Range Ex VAT: 0 - 50
