StarTech.com 10 ft IEEE-1394 FireWire Cable 6-6 M/M
Quicklinx: 402PWS00 Mfr#: 1394_10
Turn up the heat with the 10 foot StarTech.com IEEE-1394 FireWire cable. Capable of transferring data at up to 400Mbps and daisy chaining up to 63 devices with cables up to 14 feet long, FireWire is a technology that StarTech.com is excited to offer. Providing the high-speed link required for FireWire peripherals to communicate with a PC or with each other as well as the ability to transfer digital video files from camcorders to PCs, each cable is manufactured using IEEE-1394 rated wire for full compatibility and reliability.
StarTech.com 10 ft IEEE-1394 FireWire Cable 6-6 M/M - IEEE 1394 cable - 6 PIN FireWire to 6 PIN FireWire - 3 m
IEEE 1394 cable
Length
3 m
Connector
6 PIN FireWire - male
Connector (Second End)
IEEE 1394
P/N: CB1394_2, EC13942, MPEX1394B3, PCI1394MP, PEX1394A2V, PEX1394B3LP
IEEE 1394 cable
Length
3 m
Connector
IEEE 1394
