Product
StarTech.com 10 ft HDMI  to DVI-D Cable - M/M
Quicklinx: 6PF1WS00 Mfr#: HDMIDVIMM10
Type: HDMI
Length: 3m
Select:
20 in stock
£8.74 ex VAT
£10.48 inc VAT
Standard delivery Delivered within 3-5 working days
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM10 10-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 10 ft HDMI to DVI-D Cable - M/M - video cable - 3 m
Cable
Video cable
Length
3 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
P/N: SP123DP2DVI, HDMI2HDMI, ST121HDMIT, HDMIEQ, ST122HDMI
Cable Type
Video cable
Length
3 m
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
Limited warranty - lifetime
StarTech.com 2 Port HDMI Video Splitter and Signal Amplifier, HDMI Video Extender over Cat 5, TripleHead DisplayPort to DVI Multi Monitor Adapter , StarTech.com Converge A/V HDMI Equalizer
Type: HDMI
Length: 3m
Price Range Ex VAT: 0 - 50
