StarTech.com 10 ft HDMI  to DVI-D Cable - M/M
Quicklinx: 6PF1WS00 Mfr#: HDMIDVIMM10
Type: HDMI
Length: 3m
Select:
More than 50 in stock
£8.68 ex VAT
£10.41 inc VAT
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM10 10-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 10ft HDMI to DVI D Adapter Cable - Bi-Directional - HDMI to DVI / DVI to HDMI Adapter for Your Computer Monitor (HDMIDVIMM10) - video cable - 3 m
Cable
Video cable
Length
3 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
P/N: BOX4CABLE, DKT30CDVPD, HDBOOST, HDVGADP2HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121USBHD, ST121WHDS, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, STDHVHDBT, TB32HD2, USB32DVCAPRO, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS421HD4KA, VS424HD4K60
Cable Type
Video cable
Length
3 m
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
Limited warranty - lifetime
P/N: BOX4CABLE, DKT30CDVPD, DP2DVI, DP2DVI2, DP2DVIS, DP2HD4KS, DP2HDMI, DP2HDMI2, DP2HDMIADAP, DVI92030202L, DVISPL1DD, HDBOOST, HDMI2HDMI, HDMI2VGA, HDMIPNLFM3, HDVGADP2HD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, MDP2HD4KS, MDP2HDMI, MDP2HDW, MHD2HDF11, MSTDP123HD, MSTMDP123HD, MSTP3MDPUGBK, MSTS3MDPUGBK, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121HDFXA, ST121HDWP, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTPHD2, ST121WHD2, ST121WHDS, ST122DVIA, ST122HD4K, ST122HD4KU, ST122HDMI2, ST122HDMILE, ST124DVIA, ST124HD4K, ST124HDMI2, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST424HDBT, STDHVHDBT, STHDBTRX, SV831DVIU, TB32HD2, USB2DVIE3, USB2DVIPRO2, USB2HDCAPS, USB32DVCAPRO, USB32DVIEH, USB32DVIPRO, USB32HD2, USB32HD4K, USB32HDDVII, USB32HDEH, USB32HDES, USB32HDPRO, USBC2DVCAPRO, UVCHDCAP, VGA2HD2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221HD4K, VS221HD4KA, VS221HDQ, VS221VGA2HD, VS222HD4K, VS222HDQ, VS420RDVIA, VS421HD4K, VS421HD4KA, VS421HDPIP, VS424HD4K60, VS424HDPIP, VS440HDMI, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
6PF1 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.17
6PF1 StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.55
6PF1 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.66
6PF1 StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £8.68
6PF1 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £7.77
Type: HDMI
Length: 3m
Price Range Ex VAT: 0 - 50
