Extend your DVI-I (dual link) connection by 10ft. The DVIIDMF10 DVI-I Dual-Link Digital Analog Monitor Extension Cable allows you to extend the connection distance between your DVI-I devices by up to 10-feet.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
- StarTech.com 10ft DVI-I Dual Link Digital Analog Monitor Extension Cable - DVI extension cable - 3.05 m
- DVI extension cable - dual link
- Length
- 3.05 m
- Connector
- DVI-I - male
- Connector (Second End)
- DVI-I - female
- FCC
- Black
- Limited lifetime warranty
- Designed For
- P/N: ST121UTPDVEU, USB2DVIPRO, ST121UTPDVGB, USB2DVIE, ST121UTPDVI, DVIEQ, USB2DVI, AGPVID5500A
- TMDS Links
- Dual link
- Length
- 3.05 m
- Black
- Connector
- 24+5 pin combined DVI - male
- 24+5 pin combined DVI - female
- FCC
- Designed For
- StarTech.com DVI Video Extender Equalizer, DVI Video Extender over Cat5, Professional USB to DVI Multi Monitor Video Adapter, USB DVI External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI, USB DVI VGA External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI
