StarTech.com 10 ft DVI-D Single Link Monitor Extension Cable - M/F
Quicklinx: 3ZL5WS00 Mfr#: DVIDSMF10
Select:
  • 3m
This 10ft single-link DVI-D extension cable offers a high quality connection that allows you to get the most out of your high-end digital video card and flat-panel digital LCD monitor.
With DVI-D technology, no digital-to-analog conversion is necessary, so the signal is delivered faster and stronger than a standard monitor cable signal. The plug and play-compatible, all-digital connection provided by this DVI-D extension cable is also ideal for connecting laptop computers to digital projectors for crystal-clear presentations.
By interfacing two digital signals directly, you'll experience faster, higher-quality images. This single-link cable works with virtually any DVI digital flat panel LCD monitor and allows high-speed DVI video data transmissions of up to 4.95 Gbps.
StarTech.com DVI Extension Cable - 10 ft - Single Link - Male to Female Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord (DVIDSMF10) - DVI extension cable - 3 m
DVI extension cable - single link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
Plug and Play
P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
DVI extension cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Plated Connector
Nickel
Length
3 m
Connector
18+1 pin digital DVI (Single-Link) - male
18+1 pin digital DVI (Single-Link) - female
Plug and Play
