Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM10 10ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
- StarTech.com 10 ft DVI-D Single Link Cable - M/M - DVI cable - 3 m
- DVI cable - single link
- Length
- 3 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- Plug and Play
- Black
- Limited lifetime warranty
- Designed For
- P/N: SP123DP2DVI, IP2DVI, PEX2PCI4GB, PEX2PCI4, ST122DVIGB, ST124DVI, ST122DVI
- DVI cable
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Single link
- Length
- 3 m
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- Plug and Play
- Designed For
- StarTech.com 2 Port DVI-I Video Splitter - Digital and Analog, 4 Port DVI-I Video Splitter - Digital and Analog, Ethernet to DVI Video Adapter over IP, PCI Express to 4 Slot PCI Expansion System, TripleHead DisplayPort to DVI Multi Monitor Adapter
