StarTech.com 10 ft DVI-D Single Link Cable - M/M
Quicklinx: 76RVWS00 Mfr#: DVIDSMM10
Type: DVI
Length: 3m
31 in stock
£7.89 ex VAT
£9.46 inc VAT
Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM10 10ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
StarTech.com 10 ft DVI-D Single Link Cable - M/M - DVI cable - 3 m
DVI cable - single link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
Plug and Play
P/N: BOX4CABLE, CDP2DVIW, CDPVGDVHDBP, DKT30CDVPD, DP2DVIADAP, DVI2HDMIA, DVI2VGACON, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, PEXHDCAP2, PEXHDCAP60L2, ST122DVIA, ST124DVIA, SV431DD2DU3A, SV565FXDUSA, SV565UTPDUV, USB32DVCAPRO, USB3HDCAP, USB3SDOCKD, USB3SDOCKHD, USBC2DVCAPRO, VHDCI24DVI, VSEDIDDVI
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Length
3 m
Connector
18+1 pin digital DVI (Single-Link) - male
Plug and Play
P/N: BOX4CABLE, CDP2DVIW, CDPVGDVHDBP, DKT30CDVPD, DP2DVIADAP, DVI2HDMIA, DVI2VGACON, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, PEX2PCI4, PEX2PCIE4L, PEXHDCAP2, PEXHDCAP60L2, ST121UTPDVI, ST122DVIA, ST124DVIA, SV431DD2DU3A, SV565FXDUSA, SV565UTPDUV, USB32DVCAPRO, USB3HDCAP, USB3SDOCKD, USB3SDOCKHD, USBC2DVCAPRO, VHDCI24DVI, VS420RDVIA, VSEDIDDVI
76RV StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
76RV StarTech.com 20 ft DVI-D Single Link Cable - M/M In Stock £18.57
76RV StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
76RV StarTech.com 18in DVI-D Single Link Cable - M/M In Stock £4.97
76RV StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
76RV StarTech.com 25 ft DVI-D Single Link Cable - M/M In Stock £17.69
Type: DVI
Length: 3m
Price Range Ex VAT: 0 - 50
