StarTech.com 10 ft DVI-D Single Link Cable - M/M
Quicklinx: 76RVWS00 Mfr#: DVIDSMM10
Type: DVI
Length: 3m
21 in stock
£8.02 ex VAT
£9.62 inc VAT
Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM10 10ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
StarTech.com 10 ft DVI-D Single Link Cable - M/M - DVI cable - 3 m
DVI cable - single link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
Plug and Play
P/N: SP123DP2DVI, IP2DVI, PEX2PCI4GB, PEX2PCI4, ST122DVIGB, ST124DVI, ST122DVI
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Length
3 m
Connector
18+1 pin digital DVI (Single-Link) - male
Plug and Play
StarTech.com 2 Port DVI-I Video Splitter - Digital and Analog, 4 Port DVI-I Video Splitter - Digital and Analog, Ethernet to DVI Video Adapter over IP, PCI Express to 4 Slot PCI Expansion System, TripleHead DisplayPort to DVI Multi Monitor Adapter
76RV StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
76RV StarTech.com 20 ft DVI-D Single Link Cable - M/M In Stock £18.57
76RV StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
76RV StarTech.com 18in DVI-D Single Link Cable - M/M In Stock £4.97
76RV StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £8.02
76RV StarTech.com 25 ft DVI-D Single Link Cable - M/M In Stock £17.69
Type: DVI
Length: 3m
Price Range Ex VAT: 0 - 50
