Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM10 10ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
StarTech.com DVI Cable - 10 ft - Single Link - Male to Male Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord - DVI to DVI Cable (DVIDSMM10) - DVI cable - 3 m
DVI cable - single link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
Plug and Play
P/N: BOX4CABLE, CDP2DVIW, CDPVGDVHDBP, DKT30CDVPD, DP2DVIADAP, DVI2HDMIA, DVI2VGACON, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, PEXHDCAP2, PEXHDCAP60L2, ST122DVIA, ST124DVIA, SV431DD2DU3A, SV565FXDUSA, SV565UTPDUV, USB32DVCAPRO, USB3HDCAP, USB3SDOCKD, USB3SDOCKHD, USBC2DVCAPRO, VHDCI24DVI, VSEDIDDVI
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Length
3 m
Connector
18+1 pin digital DVI (Single-Link) - male
Plug and Play
P/N: BOX4CABLE, CDP2DVIW, CDPVGDVHDBP, DKT30CDVPD, DP2DVIADAP, DVI2HDMIA, DVI2VGACON, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, PEX2PCI4, PEX2PCIE4L, PEXHDCAP2, PEXHDCAP60L2, ST121UTPDVI, ST122DVIA, ST124DVIA, SV431DD2DU3A, SV565FXDUSA, SV565UTPDUV, USB32DVCAPRO, USB3HDCAP, USB3SDOCKD, USB3SDOCKHD, USBC2DVCAPRO, VHDCI24DVI, VS420RDVIA, VSEDIDDVI
76RV StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.78
76RV StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F In Stock £9.57
76RV StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £73.06
76RV StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £77.49
76RV StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £10.14
76RV StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £71.67
