StarTech.com 10 ft DVI-D Dual Link Cable - M/M
Quicklinx: 3ZL9WS00 Mfr#: DVIDDMM10
Type: DVI
Length: 3m
£10.60 ex VAT
£12.72 inc VAT
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM10 10ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 10 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 10 ft DVI-D Dual Link Cable - M/M - DVI cable - 3 m
DVI cable - dual link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: RKCONS2001GB, USB2DVIPRO, RACKCONS2001, DP2DVID, SV431DVIDGB, DVI2HDMI, USB2DVIE, HDMI2DVI, SV431DVIDDU, SV431DDUSB, SV231DDUSB, USB2DVI, VID2DVIDTVGB, VGA2DVIIGB, VGA2DVII, VID2DVIDTV, SV421DVIDD, SV221DVIDD, SV221DVI
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
3 m
Connector
24+1 pin digital DVI - male
StarTech.com 2 Port DVI PS/2 KVM Switch, 4 Port DVI Dual Monitor KVM Switch with PS/2, Composite and S-Video to DVI-D Video Converter with Scaler, DisplayPort to DVI Dual Link Active Converter – USB Powered, DVI and Digital Audio to HDMI Converter, HDMI to DVI-D Video Converter with Audio, High Res RackMount LCD Console for 19" Rack, Professional USB to DVI Multi Monitor Video Adapter, USB DVI External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI, USB DVI VGA External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI, VGA to DVI-I Video Converter with Scaler , StarTech.com Converge A/V HDMI to DVI-D with SPDIF Audio Converter
3ZL9 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
3ZL9 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £12.91
3ZL9 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
Type: DVI
Length: 3m
Price Range Ex VAT: 0 - 50
